It is currently Sat Sep 13, 2025 3:40 pm
 Post subject: X-bracing pattern
PostPosted: Sun Aug 16, 2020 5:10 pm
First name: Brad
Last Name: Combs
Hello,
I’m looking to x-brace a tenor uke. This is what I have in mind. It’s just laid out a quick test, not the final layout but just to begin to get an idea.
Any thoughts on the bracing? I’m just looking at width at the moment, not height. I could lose the finger braces maybe?
Brad
 Post subject: Re: X-bracing pattern
PostPosted: Sun Aug 16, 2020 5:45 pm
First name: Brad
Last Name: Combs
My thought is peak everywhere as usual and taper all braces. The lower X legs, the finger braces and the tonebar taper to zero. The upper X legs get tucked. Scallop the upper transverse.
Brad
PostPosted: Sun Aug 16, 2020 6:37 pm
First name: Aaron
I use a bracing pattern very similar, on my Tiples.
I guess you’re stringing with steel?
In a conversation with Les Nunes about 20 years ago (I think it was him), Martin’s first ukulele was X-braced, like their guitars. Didn’t work for them - guess who’s bracing pattern they ended up with. Like I said, 20 years ago, but the names match with the conversation.
PostPosted: Sun Aug 16, 2020 6:56 pm
First name: Brad
Last Name: Combs
Thanks, Aaron.
I was not planning on steel string but perhaps I’ll have to do that to effectively drive a top that’s x-braced?
The top for this is ziricote and it’s going to have to get really thin in order to work and I was thinking the x helps here compared to the fan braces given how prevalent ziricote is to cracking.
Maybe that’s not the case, what is your thought?
PostPosted: Mon Aug 17, 2020 12:22 am
First name: Aaron
You’re using a very hardwood hardtop, then you’re planning on bracing it with a pattern that could effectively kill the top (with nylon strings). Of course, thinning the top too much could kill it too.
My thought is that if I had to do it for a customer, I wouldn’t. But, I’d do it for myself, just to test, and see if its something I’d do. I know some guys doing a modified Taylor style V with success, but not without testing first.
Note: My first Tiple for a customer was #2, because #1 was my prototype. I was conservative with the bracing and break angle (heavy, and low), but with 10-strings and Spruce top, it came out good.
These users thanked the author Aaron O for the post: bcombs510 (Mon Aug 17, 2020 12:24 am)
PostPosted: Mon Aug 17, 2020 1:08 pm
First name: doug
Last Name: powdrell
City: hilo
State: big island
Been doing X bracing for past 40+ ukuleles....no finger braces....I taper and tuck X's, thin the rim after box closed.....don't overbrace!!!!! good luck!
These users thanked the author powdrell for the post (total 2): Pmaj7 (Sun Aug 23, 2020 12:26 am) • bcombs510 (Mon Aug 17, 2020 1:11 pm)
PostPosted: Mon Aug 17, 2020 1:11 pm
First name: Brad
Last Name: Combs
Awesome. Thanks! Do you add a tonebar?
PostPosted: Mon Aug 17, 2020 1:51 pm
First name: doug
Last Name: powdrell
City: hilo
State: big island
On an 8 string yes.....otherwise no.......
These users thanked the author powdrell for the post: bcombs510 (Mon Aug 17, 2020 1:53 pm)
PostPosted: Mon Aug 17, 2020 1:53 pm
First name: Brad
Last Name: Combs
Thanks, Doug!
PostPosted: Sat Aug 22, 2020 7:52 am
I have used a very similar pattern minus the finger braces for a couple of baritone ukes strung with steel strings. I used 1/4inch x 11/32 height for the x and tone bar. They were tapered towards the rims. I have never tried nylon strings with this layout but if lightened up sufficiently should be fine.
Sent from my SM-A520F using Tapatalk
These users thanked the author CraigSz for the post: bcombs510 (Sat Aug 22, 2020 7:54 am)
PostPosted: Sun Aug 30, 2020 8:40 pm
First name: Brad
Last Name: Combs
I haven’t closed the box yet, here is where I am on the bracing for the top. I feel like the X is still too high but when tapping it rings pretty well.
For those that have done an X on a uke, care to share or comment on the brace height?
Any feedback is appreciated.
Thanks!
Brad
PostPosted: Fri Sep 04, 2020 11:52 am
First name: doug
Last Name: powdrell
City: hilo
State: big island
X looks fine.....bottom brace could be 'tone killer'.........good luck.....
These users thanked the author powdrell for the post: bcombs510 (Fri Sep 04, 2020 7:58 pm)
PostPosted: Fri Sep 04, 2020 8:01 pm
First name: Brad
Last Name: Combs
Thanks.
I decided to keep going and take the X lower and the tonebar lower. It’s now ringing the way I would expect so I closed the box.
Thanks for all the feedback everyone!
Brad
